Discuss Wanting a trimless finish with bullnose tiles but not possible due to cut edge in metro pattern? in the Canada Tile Advice area at TilersForums.com.
mofonyx
Hi,
Our bathroom is being renovated. I wish not to have a trim and went with a range of premium tiles that offered a short rounded edge (bullnose) tiles (cut out page in catalogue here Imgur - https://imgur.com/gIEQwz2 ). We are using 6 x 3 inch tiles arranged in overlapping 'brick/metro pattern'. To avoid a trim, I planned on using a bull nose to the short edge of the finish.
Essentially, this means every alternate tile on the finishing edge has to be cut in half. In my mind, the rounded edge will always face out, with cut tiles alternating into the rest of the wall with the next tile like this Imgur - https://imgur.com/08vthOx
Our tiler has said that the cut edge cannot be facing inside against a finished tile edge as this would give an undesirable appearance. Partly because the cut edge would be sharp and the grout would not make the finish flush. He advised that the cut edge should face out and be finished with a trim which would be more desirable. Our tiles are flat, and not beveled so I thought this would not be a problem!
Please advise. Thank you!
Blunt Tool
Hi,
If your tiles are not bevelled edge and just flat then your tiler should be able to rectify cut edge good enough to put in grout line with the use of polishing pads wether hand or machine ones or better still Sait fine grit discs
mofonyx
Thank you all for replies. After a heated discussion with my bathroom fitter, we have agreed to align the tiles with the rounded edge outside. He has a wet saw and I advised him to finish the edge with rubbing stone to get a good finish. He is convinced this is unconventional and the finish would be undesirable.
Just as an aside, in the event that the finish is undesirable, would a decent tiler be able to come and re-tile the small section without too much disruption?
Blunt Tool
How is the tiler going to make a factory made edge like that ?
When he cuts the tile you will see the biscuit, the whole edge will be the biscuit :confused2:
This is the picture the OP supplied, no bevel, looks like white back not brown, and he has purchased the bullnosed tiles so wouldn’t be at all hard to do as customer asks
Blunt Tool
I think that was just an example pic of the way the wanted the tiles cut.
The biscuit could still be brown.
For me it would still work. Tiler needs to make the judgement.
Yes yes you know everything OP has, who am I to argue with such a knowledgeable plumber as yourself! Just read his first post!!
Reply to Wanting a trimless finish with bullnose tiles but not possible due to cut edge in metro pattern? in the Canada Tile Advice area at TilersForums.com
Hi, 1200 wide tray and tiling shower enclosure recess with metro tiles where the 1200 wide...
We recently completed the (rectified porcelain) floor tile installation in the bathroom and...
Hi all, I've had a go at tiling our cloakroom loo and its going ok, (I am extremely slow, it...
Hello! First time tiling a bath. My issue is that the shower wall is about .5" (1.5cm) narrower...
    Votes: 7 5.2%
    Votes: 13 9.6%
    Votes: 8 5.9%
    Votes: 39 28.9%
    Votes: 16 11.9%
    Votes: 33 24.4%
    Votes: 3 2.2%
    Votes: 2 1.5%
    Votes: 20 14.8%
    Votes: 18 13.3%
    Votes: 15 11.1%
    Votes: 7 5.2%
    Votes: 3 2.2%
    Votes: 3 2.2%
