Washing machine drain hose glued!! Discussion Thread
Hi,
Thanks for looking. I am getting a new washing machine who will install, disconnect, recycle it, etc as long as its a straight forward process.
Which it may be, however, we moved our old machine from one house to another and the plumber who disconnected it cut off the end of the waste pipe hose so the next plumber had to use a hose pipe clip/clamp ( see pics) & appears to have used glue.
So, before they bring the machine on Mon, I wanted to make sure that they won't look at it and refuse to install/disconnect it! I'm not sure if i need to buy a new part for it as it looks like it screws off (see pic with yellow circle). If so could you let me know what the parts called, etc? I'm a complete novice!!
Thank you for your help.
Washing machine drain hose glued!! for the original thread on Plumbers Forums
Hi,
