Discuss Waterproof tape in the Canada Tile Advice area at TilersForums.com.
Using AquaDefence to seal an en-suite floor today & ran out of Mapei tape.
Got me thinking, the stuff is a fortune, what other tapes do peeps use?
Any good recommendations?
£18.34 for 10 metres from CTD. Including vat.
That's a great price for that tape, I use the mega tanking kits all the time now , find them excellent !This is what I use all the tile for wetrooms and tanking showers/overbath showers
Mega Waterproof Self Adhesive Joint Sealing Tape 80mm wide x 10m Long
7kg of weber sys.protect is £32 inclusive from ctd, that's just for the liquid then the tape is £18. The liquid will easily do 6 m2 with 2 coats.
What's the Weber sys like Bri, is it similar to say aquadefence?
I worked out the price that its cost them to tank the floor so far 15m tape + 15kg aqua =£195
If I had used Weber it would have been=£100
Good thing I'm not paying for it..
I've not used the aqua defence but, if you've used BAL WP1, it's pretty much the same as that. My ideal liquid system would be the weber tape with the Ardex paste. The Ardex kits only come with scrim tape for jointing and that isn't the best IMO.
I admit it's not the easiest kit to work with but, I like the texture of it and it feels very robust compared to some of the other kits such as WP1 and sys.protect.
The finish of it is good Bri, gives a right good key for the adhesive to stick to.
I've got some left, think I will just use it on a small wall to test it out again & try & mix it thinner.
Reply to Waterproof tape in the Canada Tile Advice area at TilersForums.com
