davidsmerv
Anyone any ideas for waterproofing an Aqua dec other than Tilesafe, ive done a few with Durals Durabase which as im sure most of you will know is the 1m wide roll of fleecy waterproofing fabric. It has worked ok but is a bit of a pain to get in around the drain of the aquadec as its not the most pliable. Im really asking as I was never much of a fan of tilesafe as it always seemed a pain to work with due to the skickyness, I believe they have now brought out a different version which may be a bit better to work with but I havent seen any to comment on it, I even have quite a bit of the original tilesafe on a roll which I should really use up to get rid of it, any ideas on a primer which would work with this as the primer that came with it is long gone.
Mervyn
Mervyn
