Rich
I keep putting up info on Mapei products, so I thought Id better be fair and put something up here for those of you that dont use Mapei...
Weber.set WF
Wall and floor adhesive
Wall and floor tile adhesive for low porosity tiles
Flexible, wall & floor tile adhesive
Rapid strength tile adhesive
Rapid strength tile adhesive for low porosity tiles
Flexible, rapid strength tile adhesive
Highly flexible floor tile adhesive
Weber.set WF
- Standard setting (24 hours)
- For fixing ceramic tiles and mosaics to walls and floors
- Available in grey and white
- Properties can be enhanced with Weber AD230 and Weber AD250
- Supplied in 10 & 20 kg (white) 10 & 20kg (grey) bags
- Coverage: 1.5kg of powder per m2 for every 1mm of bed thickness
- For fixing ceramic and porcelain tiles to walls and floors
- Polymer modified to provide a strong bond onto tiles/substrates with low porosity
- Available in white
- Supplied in 20kg (white) bags
- Highly ploymer modified
- For fixing ceramic and pocelain tiles to walls and floors
- Will accommodate limited movement, from heated screeds and/or over boarded wooden floors
- Supplied in 20kg (white) 20kg (grey) bags
- Rapid setting, grout in 2 hours
- For fixing ceramic tiles to walls and floors
- Specifically developed to allow easy bedding of large format tiles
- Available in light grey and white
- Supplied in 20kg (white) 10&20kg (light grey) bags
- Polymer modified tp increase bond to tiles and substrates with low porosity
- Supplied in 20kg (light grey) bags
- Highly polymer modified
- Will accommodate limited movement, from heated screeds, and/or over-boarded wooden floors
- Medium setting, grout in 5 hours
- Accommodates movement and bonds to difficult surfaces
- For fixing ceramic and porcelain to floors
- Two component system
- Available in grey
- Supplied in 7kg with 3.75lt of liquid of 25kg with 13.5lt of liquid
- Coverage: 0.8kg of powder perm2 for every 1mm of bed thickness
