Discuss weber slc in the UK Tiling Forum area at TilersForums.com.
Haven't used Weber Charlie, I use Uzin LevelStar 170. 25kg takes 6.5 L of water. Flows really well.
[DLMURL]http://www.uzin.com/uploads/tx_dddownloadmatrix/NC_170_LevelStar_oekoine_GB_0110.pdf[/DLMURL]
You should NEVER put more water in than the manufacturer recommends, otherwise you will be tiling onto a very weak layer of laitance, so if Weber doesn't flow well at 5.25 L then that's as good as that brand SLC will get. Time to try something else.
Uzin is very good.
thanks mike, I know what your saying! I was using ball stopgap and liked it but trying to find a cheaper flexing alternative! I like the sound of the one you have mentioned but never heard of it over here
Back to the OP.. about Weber and not uzin.
Weber floor flex IMHO flows very good but you must float it to required thickness,, it will not flow on it's own ..
Reply to weber slc in the UK Tiling Forum area at TilersForums.com
