Mr potato
I am looking to put in two wet shower areas and my plumber has said Wedi are good. looking at buying the the 1400x900 trays and using wedi backer board for walls. I have looked at the wedi kit and see that only water proof tape and cement base flexible adhesive is advised to seal joints etc. I presume the wedi board is fully waterproof but will the adhesive let the tape down if it is not epoxy ? and truly waterproof.
What do I need to use to seal the tape and which adhesive and grouts should i use to remain fully water proof. Also been asked to see if mozaics or pebble mats are ok on a wedi tray. Point loading was my initial concern
