hi all,what thickness of wedi would you reccomend to fix mosaics to in a steam rooom walls
block walls so going to dot and ab the wei and also scrw it to straighten the alls as well
is 10mm sufficient or should i go for 20mm wedi
ta in advance
there is a curved stud ceiling so will i need 20mm for that to cut throught he board to form my shape or do you suggest thicker i thought 20mm would be ok for this
ta in advance
