Guest viewing is limited
Tiling Tool Suppliers
Discuss wet cutter different quality?? in the Tile Cutters (Manual & Wet Cutters) area at TilersForums.com.
tile
Hi guys can anyone tell me what the difference will be between wet tile cutters.
I see you go on about rubi cutters so am thinking of 1 around the 250 - 300 mark but what if i went for a cheap d i y cutter from 30 - 100 pounds would it be a major difference in cutting, will it make my job easier to go for a more expensive 1.
thanks, andy.
off to bed now so will read any replies in morning. if any.ta:huh2::huh2::huh2:
Gazzer
If you look on Ebay and Screwfix you will see cutters by FERM, i had on a few years ago for about £70 and its still going. The tray leaked but sorted that and the water pump filter got blocked quick but thats sorted too. Not bad for the money but the motor is not strong enough in my opinion. It also has a limited cut length of about 36cm.
I have the Rubi DW250n now....havent tried it yet though.
GazTech
The quality of the motor in the cutter is what makes the difference...you don't want a motor to pack up after a yr or so do you.....and the build quality comes into it as well..........cheap cutters are great when you first set out tiling ..but your tools are your livelihood so invest in good ones if you decide to stop in the trade is my advice....
I agree with Dave...a third the price will be a third the life....if you were a skydiver....parachute for £100 or £500 ?........Gaz
DHTiling
This is my day to day wet cutter...these are the dog danglies of cutters..had one for yrs and it has never let me down.....removable rip guide as well for plunge cuts....
Rubi Diamant D-200 Wet Tile Saw
Technical Information
  • Cutting Length: Unlimited
  • Depth of cut: 35 mm (1,3")
  • Maximum width for miter cuts: 42 cm (16")
  • 0,88 kW (1,2 hp) single-phase motor. Available in 120V / 50Hz, 230 V/ 50 Hz for the UK or 230 V / 50 Hz
  • RPM: 2875
  • Blade capacity: 200 mm (8")
  • Tile Saw Dimensions: 47 cm x 47 cm x 26 cm (18" x 18" x 10")
  • Weight: 16 kg (35.3 lb)
General Information
  • 100% Rustproof wet saw. Table, internal structure, and chassis made entirely of stainless steel
  • Cuts gres, ceramic, glass, tiles, marble, and other materials
  • 200 mm (8") blade, rip guide, and thermic security switch included
  • Tip-up Table for mitering up to 42 cm (16") tile
not cheap though at around £580..but will last for yrs and yrs.....:thumbsup:
Reply to wet cutter different quality?? in the Tile Cutters (Manual & Wet Cutters) area at TilersForums.com
Hello, I hope you can help. I'm get despondent cutting 9mm glazed porcelain tiles, 300 x 900mm...
  • Sticky
my trusty old wickes wet tile cutter never got returned last time i lent it out. but only cost...
5K
I searched but did not find an answer. I been advised to get a wet tile cutter, I plan to cut...
Popular Tile Cutter Threads
    Votes: 5 5.9%
    Votes: 6 7.1%
    Votes: 5 5.9%
    Votes: 22 25.9%
    Votes: 13 15.3%
    Votes: 25 29.4%
    Votes: 3 3.5%
    Votes: 2 2.4%
    Votes: 18 21.2%
    Votes: 14 16.5%
    Votes: 6 7.1%
    Votes: 5 5.9%
    Votes: 3 3.5%
