Tiling Tool Suppliers
Discuss Wet cutter mitre 600 x 300 porcelain in the Tile Cutters (Manual & Wet Cutters) area at TilersForums.com.
UK
Hi all
I am looking to purchase a new wet cutter and after reading the forum it seems the RUBI nd200 or the Norton TT200 are rated quite well and would be contenders.
However, I have 600 x 300 Porcelain to cut with mitred edge along the 600 side, from images and videos of the above machines it seems that there isn’t space for 300mm between the fence and the blade.
Could anyone who has experience with these machines tell me if this is possible on them or if they are simply not capable, or if it is possible how you go about it.
Many thanks.
Blunt Tool
Best advice I could give you is do not set up wet saw on floor get yourself a decent foldable work table that is strong,broad and stable. This makes it easier to control tile pushing thru at a steady controlled pace at a comfortable steady height. Trying to lean over on your knees at floor level makes it unsteady and uncontrolled
UK
Thanks for the replies.
Waluigi when you say cut mitre by hand, do you mean with angle grinder?
I had considered that yes, was just looking for a method for the mitres with more consistent results and less dust, but sure I could do it that way.
I would setup whatever method on a sturdy bench thanks callatiler.
I’ve also realised that I will probably need to mitre the edge of longer cut pieces say 500mm, pretty sure that won’t go through on the machines mentioned unless I’m looking at them wrong.
I guess only a bridge saw would do this?
Blunt Tool
Best advice I could give you is do not set up wet saw on floor get yourself a decent foldable work table that is strong broad and stable. This makes it easier to control tile pushing thru at a steady controlled pace at a comfortable steady height. Trying to lean over on your knees at floor level is makes it unsteady and unc
i don’t understand what you mean? You say won’t get a 500mm thru wet saw and I have already said I’ve put thru 600mm and bigger in fact the machine will cut infinity it’s just holding it gets more difficult
UK
I may be looking at this wrong then.
The way I see it from looking at pictures of the unit is that you tilt the table of the nd200 to 45 degrees, then with the fence at the bottom where you rest the tile you have a gap between the fence and the blade. This would be the maximum tile size you could pass through, assuming that the tile was face up on the bed.
Once cut you have a piece with a mitred edge but can only be as big as the gap between the blade and the fence.
Am I seeing this completely wrong?
When using the fence you always have a limitation on size.
Blunt Tool
Think the video you are watching shows guy setting fence and doing mitre on top edge as bottom sits on fence. This would limit size of tile to size of fence side of table. But if you set the fence to as near the blade as needed depending on thickness of tile for mitre then it is infinity
UK
Ahhh, I see what you’re saying. So when you’re pushing the tile through you only have the thickness of the tile touching the bed as the tile would be 90 degrees to the bed.
Right, makes sense, yes I was viewing that video and hasn’t thought about it as you’re suggesting.
Thanks very much
Blunt Tool
Thanks very much
Yes set fence to thickness of tile then 1mm in from it, face down on bed then slowly thru let the blade do its job.
Reply to Wet cutter mitre 600 x 300 porcelain in the Tile Cutters (Manual & Wet Cutters) area at TilersForums.com
Hello, I hope you can help. I'm get despondent cutting 9mm glazed porcelain tiles, 300 x 900mm...
  • Locked
Hi guys A little advice if possible I have a bathroom 2.6 x1.9 on joists 18” gaps New weyroc...
Hi, new to forum but tiled a few DIY jobs for friends and family over the years. Can anyone...
10K
I searched but did not find an answer. I been advised to get a wet tile cutter, I plan to cut...
Hi guys, been a keen reader of the forum for a few weeks now. Getting ready for a DIY bathroom...
Popular Tile Cutter Threads
UK
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
