shick
Hi
I am after some advice on the following,
I have been to look at a job which had problems in a wet room, i removed the floor tiles (very easily)
which were fixed directly to the Anhydrite underfloor heated screen.
I say its anhydrite as i have laid screeds before but this seems a lot finer and you can scratch layers of fine dust off.
What i am looking for is the correct way to reconstruct the wet room and what tried and tested materials should i use, the cost is not an issue it just needs doing correctly.
I have removed the wall tiles too as they have been fixed directly onto plasterboard and this is soaking.
I will be using hardi backer boards for the shower wall areas.
Do i need to sand the screed down (its was laid about 4 years ago) as i did read this in a thread
somewhere.
I am aware that uncoupled matting is advised, floor levels could be an issue if using ditra 25 matting, i was wondering if there was a suitable fleece membrane which would keep the door floor level difference to a minimum or am i best sticking with Ditra 25 or even durabase CI
thanks
Mark
somewhere.
thanks
Mark
