Discuss Wet room, cement on top of Anhydrite screed in the Tanking and Wetrooms area at TilersForums.com.
Hi guys
Long time reader and lurker, got so much great advice...
Quick question, i have a Anhydrite screed currently that was put down in a wet room (Wet UFH 50mm thick) it is currently 50mm lower than the finished floor height needs to be.
My question is, would it be the following buildup be suitable:
1: Prime Anhydrite with BAL DPM
2: Apply adhesive BAL Rapid Set with uncoupling membrane BAL Rapid-Mat
3: Build up to just under the finished floor level with sand cement screed incorporating my falls to the linear drain
4: Tanking ontop of the new concrete (BAL Tanking kit)
5: Tile etc
Adam
Ajax123
1,213
Lincolnshire
What's the uncoupling membrane gonna do? Seems an unecessary expense and quite a lot of messing abot. Why not just use a 500gauge polythene membrane and 50mm fibre reinforced 4:1 sand cement screed. Make sure you tank the room properly before tiling
Reply to Wet room, cement on top of Anhydrite screed in the Tanking and Wetrooms area at TilersForums.com
gamer1
Hi folks, Just looked at a conservatory tiling job. Wet UFH system, set into sand and cement...
Need some help please with calculating levels and the build up of the floor to support tiling...
7K
Ipswich
Business Name
None
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.1%
    Votes: 18 11.9%
    Votes: 36 23.8%
    Votes: 21 13.9%
    Votes: 18 11.9%
    Votes: 16 10.6%
    Votes: 7 4.6%
    Votes: 4 2.6%
