Tilerinkent
HI
i have recently tiled a wet room floor using 30x30 porcelain, the plumber had installed a wet room tray and drain that was approx 800x800, i have enveloped cut in this area and the problem is the customer has a shower with body jets that when turned on are hitting the back wall (approx 2 mtrs away) and these tiles have no fall in them so the water is running out of shower area and eventually leaking through the floor to ceiling below, i have mentioned to customer that if they have a shower that is spraying water this far the whole area should have been a wet room tray so that the falls/envelope cuts would have started at the back wall, am i correct in thinking the plumber should have installed a bigger tray?
Let me know
Sean
Let me know
Sean
