Discuss Wet room floor levels in the British & UK Tiling Forum area at TilersForums.com.
Silverback
Just got a wet room job where the client has supplied all the materials. The floor is being removed and re-plyed with 18 mm ply. The customer is using warmup installation board and the tanking kit is the Impey system. They also want underfloor heating. One of my concerns is this will raise the floor level by almost 25 mm. Has anyone else had this problem and how did you solve it? I would appreciate all input.
DHTiling
Thanks Dave for your prompt reply.
Would you try using 12 mm ply or do you think this would be too flimsy?
If you are using it as the main sub-floor...then i think 18mm isnt thick enough ..honestly........22mm 0r 25mm would be stronger....it also depends whether you add extra noggins into the floor structure this will stiffen things up as well......:thumbsup:
Y
Youngoggy
Got a similar problem to this myself !
I am a bit confused about what I need to make a good floor but to keep the level down to a min.
The main floor is chip board which I was planning to put ply or insulation boards on top of before UFH and tiling :whatchutalkingabout
Which would you recomend ply or insulating boards or both, I don't want to end up with too much of a step up but realise a small one is inevitable.
Thanks Rich.
Reply to Wet room floor levels in the British & UK Tiling Forum area at TilersForums.com
We had a wet room fitted by a large company. We have issues with a few large steps where the...
hello Folks, its a tiny area. 1.8 m2. Joists are solid 3 inch wide. Area is upstairs close to...
I'm about to start on an upstairs wetroom. There will be wet underfloor heating going in via...
    Votes: 9 5.8%
    Votes: 15 9.7%
    Votes: 11 7.1%
    Votes: 45 29.0%
    Votes: 19 12.3%
    Votes: 37 23.9%
    Votes: 4 2.6%
    Votes: 21 13.5%
    Votes: 18 11.6%
    Votes: 17 11.0%
    Votes: 7 4.5%
    Votes: 3 1.9%
    Votes: 4 2.6%
