Discuss Wet room floor tile grout in the Canada Tile Advice area at TilersForums.com.
I am building a wet room, I have settled on an GRP former and tiled floor however the question is what to grout with.
Ordinary cement grout may be ok however it will be wet for much longer than on the wall and is porous. I am presuming that normal grout will mark with grease from feet etc and that after not very long will look a pigs ear. So its acrylic or epoxy grout and acrylic doesn't seem very promising.
This is a first for me and I am aware of the strict time limit on epoxy which seems to be around 45 mins; if I do the floor in sections will the next mix of grout adhere properly to what is already down and leave a watertight joint?
Any comments/advice gratefully received.
Pete
Rookery
It's probably a question of good, better and best. I daresay the vast majority of grouts used in domestic situations are cement based and with a few coats of grout sealer, will do the job fine. Mapei UCP would be my choice. Better would be the newer hybrid epoxies which have some cement content and are easier to use. It might come down to what colour you want/can get. I've used Ardex EG8 Hybrid Epoxy to good effect.
Reply to Wet room floor tile grout in the Canada Tile Advice area at TilersForums.com
Hello, I did some reading here and there, but the opinions seem to diverge at some point and I...
Hi - looking for a bit of advice if anyone has experienced this. Hands up I am completely...
Tilers Forums on FB
