Guest viewing is limited
Discuss wet room for disabled in the UK Tiling Forum area at TilersForums.com.
H
heavytrevy
Most disabled showers require the whole floor (not just the recess) to fall towards the shower waste.(check legislation in ur area)
For this the ENTIRE floor needs to be screeded to achieve the required drainage.
Also the slip rating needs to be r10 for general wet and r11 for the recess area.(again check)
If your asking these sorts of questions i Would leave the disabled wetroom to a pro.
Trev
Reply to wet room for disabled in the UK Tiling Forum area at TilersForums.com
Hi, I'm tiling the floor of a wetroom and would like some advice on the best way to lay the...
  • Sticky
Advice needed, noticed some grout that was cracked and tiles becoming loose in our en suite wet...
