Discuss Wet room on ground floor..concrete in the Canada Tile Advice area at TilersForums.com.
I
ian158
I've not done a wet room yet and tend to steer clear..but need to one day...the room is 3x2 mtrs and its concrete floor...I would need to dig up floor and path outside to get waste out..but they are going to use non slip vinyl floor, elderly lady, would I need a wet room tray , dig out floor and set tray in new screed ? Or just form a fall with a screed.Also do you get all 4 corners of room to fall towards tray? Or do you just slc up to tray ..customers has asked for this..they are using a gravity feed shower, no pump so it's not going to spray that far and the amount of spray would not be sufficient for it to fall towards waste anyway...what are your thoughts ..also wet room trays designed for tiles would not be suitable for vinyl so do they do them for vinyl?
Reply to Wet room on ground floor..concrete in the Canada Tile Advice area at TilersForums.com
Hi everyone, I’ve a fairly basic question I thinks, hope someone can help me out with. I’m...
Hi All, First time poster and tiler here. Hoping to get a bit of advice on tiling a wet room...
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
