Discuss Wet Room Retile in the Canada Tile Advice area at TilersForums.com.
rubi man
Hi guys got a little problem with a wet room hope you can help
Whats the best And i mean best money inst a problem tile addy and grout to use is a wet room round the shower that suffers from condensation/moisture on the walls after the shower is used ????
there's a air unit to draw out the air when you use the shower but its crap id like something 100% water tight if i can
its being tiled onto moisture resistant plaster board with tape and jointed joints what the best way to sort it out ie will it need pirmer ect ??
tiler is starting soon soo need to get the gear in asap thanks a million
DHTiling
MMmmm that does not sound like a wetroom to me..? .. is there no form of tanking used.. ?
tilerbarry
the best and only wetroom system I used was from Mapei. Primer G the plasterboards, mapegum wps walls and floor with a roller and mapeband tape joints and corners. kera quick and latex plus on floor and keraflex maxi adhesive on walls. Ultracolour plus grout for wall and floor and the best thin about it is 27 colours of grout with 26 matching Silicon to seal all the internal corners with. never had a call back using that system!
Reply to Wet Room Retile in the Canada Tile Advice area at TilersForums.com
  • Sticky
Shower Tile Repair - Tile Waterproofing in Brownstown MI. Schluter wet room conversion 24h...
  • Sticky
We've had a wet room installed upstairs using the Impey wet room system (see attached). The...
Good evening to all. I’m here this evening looking for some advice if you would be so kind...
Sealing Moisture resistant plasterboard Hi I am new here, I have been reading through many of...
10K
Wet Room Retile
    Votes: 14 9.4%
    Votes: 44 29.5%
    Votes: 17 11.4%
    Votes: 35 23.5%
    Votes: 21 14.1%
    Votes: 18 12.1%
    Votes: 16 10.7%
