In the second picture I can see a fair bit of damp on the floor.
And no offense but regardless of design all wet saws make a cloud of moisture which billows out in a radius around the blade itself and can travel a few feet, hence the need for side walls.
Also DeWalt needs to make tools with better bearings.
That being said I have a 12 " dewalt chopsaw which I do like for it's lightness, but have had bad experience with a few other dewalt tools which have had premature bearing failures.
Alberta Stone,
You are correct, all
tile wet saws will emit an amount of water into their environment, whether it is in the form of mist from either the blade or guard, leakage from the pan or water dripping off tiles that extend beyond the saw itself.
It is no secret that less is best when it comes to water that isn't either cooling the blade or lubricating the cut.
This is where some manufacturers fair better than others. Careful thought during the design process, honest feedback from guys like you and a continuous reliability and durability test program, in my experience make a better overall tool.
While I appreciate guys are willing to accept sacrifices in one area to see benefits in others my belief is that a saw should be designed for purpose and perform well in all areas.
No one is perfect but I can say with confidence that component durability, effective water containment and portability were high on the agenda.
Seeing your innovative solutions to common day-to-day frustrations helps us all to improve, and more importantly become more productive in what we do! :regular_smile:
