Discuss Wet UFH - Straight onto screed or plywood? in the British & UK Tiling Forum area at TilersForums.com.
I
Indy
Hello all,
Can't quite believe my luck that I've stumbled across this forum as I'm looking for a professional tiler in the East London/Essex area. :hurray:
I have a question before I get a tiler in though. I am laying UFH in the ground floor of my house, in some areas it will be on a concrete floor and in others it will be housed in a suspended floor. Do I need to plywood over the 3" screed in order to get a level floor for the tiler to work his magic on or do the tiles go straight onto the screed?
I am planning on laying 600sq stone tiles on the entire ground floor roughly 112sq/m if that helps.
Cheers
if you planing to use UFH > electric 1! then you need overlay concrete floor with insulation boars other way you will be heating concrete and you UFH will be not effective, where concrete meets plywood I would recommend to use expansion gap for the tiles (about 5mm), 12mm plywood is to thine for the stone, you should use 18mm plywood, then prime the plywood, stick insulation boards with flexible adhesive, then UFH, then latex all floor, then use Uncoupling membrane, then you can lay stone.
good luck
Reply to Wet UFH - Straight onto screed or plywood? in the British & UK Tiling Forum area at TilersForums.com
I've just had the whole ground floor of a house we are working on levelled with a pump in liquid...
Bishbbashbosh
Hi, I am trying to achieve a low floor build up including wet UFH over a new suspended timber...
    Votes: 9 5.8%
    Votes: 15 9.6%
    Votes: 11 7.1%
    Votes: 46 29.5%
    Votes: 19 12.2%
    Votes: 37 23.7%
    Votes: 4 2.6%
    Votes: 21 13.5%
    Votes: 18 11.5%
    Votes: 17 10.9%
    Votes: 7 4.5%
    Votes: 3 1.9%
    Votes: 4 2.6%
