Discuss Wet UFH in the Canada Tile Advice area at TilersForums.com.
Andyw
I am not sure if this is on the correct section but here goes.
When this is tuned after tiling you are supposed to run at a minimum temp and gradually increase over the week. My question is how is this done. Right now the manifiold is set to the lowest temp which is 35c. The ambient room temp is only 11c. I I set the stat to say 15c the UFH will constantly switch on and off. If I just run the UFH the room will get to about 22c. Or do you use the floor probe to set the temp??
Mark S
Indeed a good question
The system should have been installed to be fully functional, ie set to operate at different temperatures. The water temp is controlled via a thermostat in the manifold that blends cooler water, which is on return with hot water to meet the thermostat requirements. If the water flowing through the pipes is not raised gradually, 5 degrees per day from ambient room temp, the screed will crack from thermal shock.
The system should be 'flexible' in the range of temperature that the water flows through it. Ideally you want app.27 degrees at the screed surface as a max.
There are a few things you should know before touching any underfloor heating.
Hopefully your commissioning engineer showed you the system basics.
Have a read through the manuals left with system if your not 100% sure.
You should find how to adjust the temp stat on the manifold to increse floor temp.
The room stat controlls ambient air temp not floor temp on most systems, so check to see if you do have a floor probe fitted.
Reply to Wet UFH in the Canada Tile Advice area at TilersForums.com
Evening chaps.. Run a small company installing kitchens and bathrooms & have been asked to tile...
HI I have a wet room to do floor already tiled with under floor heating Is it possible to remove...
White Room
Hi u lot. I tiled 100 odd sqm of 450x900 porcelain onto anhydrite screed which has a water ufh...
stusgsx
I would be grateful for any advice you could give me. I have recently installed 600x450...
Good evening all. went to see and priced a job the other where the customer wants a wet room...
6K
tristanmortimer
Wet UFH
    Votes: 9 6.2%
    Votes: 13 9.0%
    Votes: 10 6.9%
    Votes: 44 30.3%
    Votes: 17 11.7%
    Votes: 34 23.4%
    Votes: 3 2.1%
    Votes: 20 13.8%
    Votes: 18 12.4%
    Votes: 15 10.3%
    Votes: 7 4.8%
    Votes: 3 2.1%
    Votes: 4 2.8%
