Discuss Wet Underfloor Heating Off Standard Boiler in the UK Tiling Forum area at TilersForums.com.
Ajax123
1,213
Lincolnshire
Didn't know where to put this one and think this has probably been asked before but here goes
I am in the process of building a loft conversion at the moment. I have been busy insulating the heck out of the roof which previously didn't have any insulation at all. The winter prompted me to do it. Anyway, I have a standard central heating system running off of an oil fired range boiler. Instead of putting a radiator up there I want to put some insulation under the floor boards and then some pipes down under the floorboards as well to act as underfloor heating. I want to use a standard Thermostatic radiator valve to switch it in and out. As the pipes will be running at around 75degrees C flow temperature I wil not need so much pipework.
Can anyone think of a reason why this would not work.
Ajax123
1,213
Lincolnshire
Mmmm, only drawbacks I can see is heat on surrounding materials, and load on the pump pumping to that hight along with boiler limits.
Sorry that's not very insightful but all I can come up with.
got no issues with the boiler or the pump capacity as it was always sized with the loft conv in mind. As for heat on materials the only thing O can think is it might dry things out a bit.
Ajax123
1,213
Lincolnshire
just read about a valve you can fit without the need of a manifold but thats as far as my knowledge goes
come on then faith give us the link....:thumbsup:
Ajax123
1,213
Lincolnshire
Im still not convinced the boiler can pump that much water that far that fast and not overload...
The boiler currently runs at around 50,000 BTU. It has a capacity of 80,000 BTU. When I installed it I made sure i had plenty of capacity. I will do some calcs on the heat loss and pipe size etc before I go ahead but am fairly confident it will be fine. I ran the main trunk pipes in 28mm copper and branche pipes in 22mm then each rad is on 15mm so I should be fine to get enough heat and water up there. It is only about 10 feet aboive the current highest point any way.
Ajax123
1,213
Lincolnshire
BTW running the pipework the way you have with 28/22/15 is the correct way to do it so this should help with the efficiency of the system. If only everyone did it the right way! :thumbsup:
I read readers digest DIY before I did it....:thumbsup:
Scott
We all have to learn somewhere :oops:
Reply to Wet Underfloor Heating Off Standard Boiler in the UK Tiling Forum area at TilersForums.com
Hi there, hoping for some help here. I am about to install a small (2.2x2.5m approx) area of...
Tiling a new extension. Cement poured screed on piped underfloor heating. Heating has been...
Hi All, I'm new to the forum and not in the trade, so please excuse my ignorance. I'm looking...
MiriamT
gamer1
Ajax123
Lincolnshire
Website
https://www.lkabminerals.com/en/products/gypsol/
What member type are you?
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
