David Dudley
Hi Guys.
Hope you don't mind taking a few minutes to look over my attached design and offer any advice you feel necessary.
I am currently planning my wetroom install in my ensuite bathroom.
I have stripped it back to brick and studs so have a completely blank canvas to work with.
My plan is to create a corner wetroom area 1.3m x 1.1m with small reveals at the side. I don't plan on having any screen on the entrance and the bath will be to one side (as shown) - boxed in and tiled onto marmox board.
My main question regards the floor -
Use a marmox showerlay (22mm thick) and then replace the floorboards with 18mm Marine ply (primed with extra noggins)
I was then thinking 6mm marmox board over the ply to bring the floor level to the height of the showerlay. waterproof tape then mapei aquadefence as a double measure
Does this sound like a sensible plan or is there a better way of doing it?
My other question regards the lack of screen. Will it be an issue having no screen? The whole floor would be tanked but obviously beyond the showerlay area the floor would be flat with no gradient so any water would just sit there (i.e. around the toilet area)
Thanks in advance.
David.
Thanks in advance.
David.
