Discuss Wetroom floor construction in the Canada Tile Advice area at TilersForums.com.
Lakey
478
Crawley
Guys
Have a wetroom to create in an extension & just wanted to clarify a couple of issues.
The wetroom is 1st floor on timber joists.
I am using an Aqua Dec tray with UFH.
My question is with the tray being 22mm at the perimeter how can I install any insulation board (Wedi or the like) & SLC to encapsulate UFH cables?
I want to have UFH on the tray also.
Any pointers would be gratefully received
Lakey
478
Crawley
Securely fix wooden packers (strips) on top of the joists to the depth you need to bring it up to even height. You could use ditra heat or Warmup DCM pro instead of going down the SLC route.
Guessed that would be an idea.
Would i then need to encapsulate UFH cables on the tray using some quick set adhesive?
Reply to Wetroom floor construction in the Canada Tile Advice area at TilersForums.com
I am sure someone will know a good practice solution. We started a wetroom last year and then...
Hi everyone, I'm looking for some advice on final floor buildup. We're installing a shower tray...
Hi I will be ripping a bath with shower out and want to replace with a wetroom, I want to keep a...
First of all, I'm sure this question has been asked a thousand times so apologies in advance! A...
Hi there I have received 2 quotes from different tilers and both have different ideas on how to...
Lakey
Crawley
    Votes: 9 6.2%
    Votes: 13 8.9%
    Votes: 11 7.5%
    Votes: 44 30.1%
    Votes: 17 11.6%
    Votes: 34 23.3%
    Votes: 3 2.1%
    Votes: 20 13.7%
    Votes: 18 12.3%
    Votes: 15 10.3%
    Votes: 7 4.8%
    Votes: 3 2.1%
