gilesweb
Hi there,
New to wetrooms and have been reading up on here trying to decide what I need to do for mine. Thanks to all the good advice on loads of threads I think I've got a plan - hoping you can check I'm not about to make a complete mess of it:yikes:
It's a 3.2 x 2 metre room and I'm planning a shower across one of the shorter sides with a Maxxus 1200 x 900 channel deck in the corner and a 1.4 metre screen positioned 1 metre out parallel to the shorter wall forming the enclosure. The other end of the room will have a bath across the other short wall and there will be a wall mounted basin in the middle of the long wall (door is on the other long wall, toilet is next door to the wetroom)
Originally there was 18mm OSB in poor condition over nice chunky joists (75mm x 17cm) at 400mm centres. I've removed this so I'm starting from scratch, hoping to get a nice secure base but not build up too much height so that I can loose it in the transition to carpet in the bedroom.
So thinking of the following for the main part of the room:
18mm WBP ply
6mm HardieBacker
Devi UFH mat/about 5mm SLC
and the Maxxus floor former sitting on 9mm WBP ply to level it up with the rest of the floor.
Then on top of the whole area a membrane (Ditra?) tiled with 10/12mm Travertine.
So am I on the right track or completely nuts!
Any thoughts gratefully received
Giles
18mm WBP ply
6mm HardieBacker
Giles
