travispuk
Hello, first post from DIYer... sorry.
I have laid down 6mm NoMorePly sheets onto 18mm ply using Mega Adhesive and screws. I also have Mira 4400 tanking membrane plus Mira Safecoat. I have seen a lot of people here on the forums point out that PVA should not be used for priming the NoMorePly boards, so my question is, I have Mira 4180 primer, I assume that this is not PVA based and therefore will not cause an issue being used on the NoMorePly boards? Should I not be using that and going for SBR primer instead?
The only place I have used PVA in my wetroom is to bond the brickwork before using a flexible tile adhesive to fix 12mm NoMorePly boards to it, therefore no direct PVA contact with the boards themselves.
I can't see anything about the mira 4180 primer being PVA based or that it should not be used in this situation.
Thanks for your help.
