Discuss What adhesive do i need Help!!! in the Australia Tiling Forum area at TilersForums.com.
I've never used wp1 but am familiar with it. When you say tank onto the tray, do you mean with the tape and membrane or will silicone between the tray and wall be enough?
That's bang on mate. I do the same but without the tape.What I do is....push tile up against the wall sitting on the tray and pencil mark a line on the tray against the tile, I use a low tack masking tape and put it up against the pencil line or just covering I made on the tray. Paint some wp1 around where the tray meets the wall and over the masking tape, fix some tape (which Bal supply with there kit) and fold onto the wall and tray, then brush another coat onto that and make sure it's pushed tight against the wall and tray, leave to dry. When your've tiled down onto the tray and adhesive has set take a very sharp knife and cut using the tile edge/face to guide you onto the tray...don't slip at this stage with the knife otherwise damage to the tray could happen....that then tanks it onto the tray.
Any questions please ask.
Reply to What adhesive do i need Help!!! in the Australia Tiling Forum area at TilersForums.com
