Discuss What adhesive to use for Jackoboard? in the Australia Tiling Forum area at TilersForums.com.
L
Lakie
Hi all, I'm new to this forum & tiling in general & am after some advice on adhesives.
I am installing a wet room area on a timber frame (to be over boarded in 18mm ply) using a Jackoboard shower tray former & will be installing 12.5mm Jackoboard onto the existing plaster walls (old tiles & 90% of the old adhesive removed).
What primer & adhesive would people recommend to fix the Jackoboard shower tray to the plywood base & to fix the Jackoboard to the walls?
I bought the whole kit from tradewetrooms.com & have their tanking kit to use as well.
All help is greatly appreciated.
Q
Qwerty
What adhesive to use for Jackobaord?
Welcome to the forum. Introduce yourself in the new members section
To answer your question though...... Jackoboard is a cement faced extruded core board and you will require a rapid setting single part flexible (SPF) cement tile adhesive to bed it down with. Any SPF adhesive from Weber, Mapei, tilemaster will be fine. You may wish to continue using this adhesive on the walls also, but you could use a standard setting SPF on the walls. Don't forget to mechanically fix the wall boards as well (jackoboard state no requirement if on a flat and even surface, but I thoroughly recommend you do.) I assume they are being fitted to a solid wall?
As for primer......just use the same manufacturers primer as the adhesive. No PVA,!!
This can be quite a big project for people that have no experience in tanking wet rooms or tiling. Are you doing this yourself?
http://www.tradewetrooms.com/downloads/dl/file/id/2/jackoboard_timber_installation_instructions.pdf
All the best.
L
Lakie
Welcome to the forum. Introduce yourself in the new members section 
All the best.
Thanks for the reply, I have been advised to use BAL bond sbr primer on the walls prior to fixing the Jackoboard.
The tanking system comes with a primer (says it's an sbr primer on the label), the tanking tape, corners & the tanking solution.
I have watched a load of installation videos for the tanking etc & feel pretty confident on that.
What should i use to mechanically fix the boards?
L
Lakie
You will require a rapid setting single part flexible (SPF) cement tile adhesive to bed it down with. Any SPF adhesive from Weber, Mapei, tilemaster will be fine. You may wish to continue using this adhesive on the walls also, but you could use a standard setting SPF on the walls.
All the best.
I've been advised by a mate who has done quite a bit of tiling to use BAL primer & adhesive & in following your advice above have stumbled upon a problem.
It appears that BAL do an SPF adhesive or a rapid set adhesive that requires an additive, but not a rapid set SPF adhesive?
Can anyone point me in the right direction please?
I need to order this today as I want to install the Jackoboard at the weekend ideally.
Stef
Reply to What adhesive to use for Jackoboard? in the Australia Tiling Forum area at TilersForums.com
I'm having a nightmare trying to establish product info from distributors. For example...
Hello All, I have a shower tray installed and it is sitting away from the wall. I am going to...
I've got an AKW Tuff form shower tray with a waste that is 10mm above the tray when fully...
Tilers Forums on FB
