Discuss What are my options? in the UK Tiling Forum area at TilersForums.com.
if you have decided to leave the tiles down, then slc, decoupling membrane then tiles, and fingers crossed, then i look forward to your next post
why have my trav tiles cracked
DIY Trainee - welcome, a lot of us here emerged from the DIY world to take on tiling full time, so I would offer you advice about what is being said here.
1. Members of the forum like Nybor, Kilty and Mike are respected by all of us here and I trust much of what they advise, but if you have received info and advice from Sir Ramic and Doug Boardley then trust me, they are always giving you the right advice - no matter how hard it is to swallow.
2. You can hire a SDS multi drill for 1/2 day for about £10 from most tool hire shops. You may find it easier to remove them using a slightly bent or shovel shape chisel. You will be able to remove those tiles and the adhesive sticking them at the rate of 5-10 sq m an hour.
3. Travertine has very little strength to resist movement - the tiles are structurally weak and crack at the slightest movement. The fixed quarry tiles are most certainly not all fully fixed and will move when walked on.
4. If you really want to tile on the quarry tiles, then swap the travertine for a porcelain tile that looks similar. Even then, use of an uncoupling membrane like ditra mat by Schluter (other companies provide products that achieve the same) should still be stuck down first - ditra mat is designed to help with unstable floor sub stratas but there are limits to the movement it will isolate - and it is expensive.
5. SLC is ideal for adjusting floor sub strata level - but by the time you have bought it and spent time laying it - you could have removed the quarry tiles. Also bear in mind that a bag of SLC costs £10-25 (dependant on use) - you will probably need more than one. It will not stop movement of any loosening quarry tiles below although some expensive SLC's now allow addition of a strengthening membrane.
6. You could hire someone to remove the tiles for less than you think. How much hassle would that save? There is nothing wrong with hiring someone to do the things you cannot do, whilst you concentrate on the things you can do.
Whatever you decide to do, is entirely up to you at the end of the day. Whatever you decide good luck and hope it all goes well.
Andy
Might of missed it but whats the substrate under the tiles
Andy
Concrete. And under that is slate. Just seen that tonight.
Guys ive been thinking more and more about this and I've decided to go with the overwhelming advise of taking the tiles up.
Thanks again.
Reply to What are my options? in the UK Tiling Forum area at TilersForums.com
