What do I do with this? (192? home) Discussion ThreadWhat do I do with this? (192? home) Electrical Advice
I need counsel!
The existing fixture was not 100 years but was apparently floating over the plaster?
No ground. No way to see which wire is which (does it matter in this case?)
There is no box on which to affix the bar to hang the new fixture and the existing...ummm insulation or something hangs out of the plaster around 5/8 of an inch. Nothing to affix anything to other than the wood you can see next to the wires.
What can I put in there to create space and stability since I am not qualified to redo all the wiring and plaster, and not able to afford a professional?
Thank you SO much for your counsel!!
What do I do with this? (192? home) for the original thread on Electricians Forums
I need counsel!
