Discuss What do you guys think in the British & UK Tiling Forum area at TilersForums.com.
gm renovations
Hi All
Need some advice please,
Just tiled a bathroom for someon ei know, the corner of the wall bowed in and i had to start to pack the tiles a bit , i only had white star, so i packed out the last few tiles by about 10/14mm, i have now left the tiles for about 5 days to dry out before grouting,
Will they be ok,
If not i will have to take the tiles off and redo the last few with bagged gear.
Any advice?
gm renovations
yea a bit annoyed,
I quoted before the bathroom fitter screwed the aquapanel in, thought to myself that great nice and flat walls, but this one wall just bowed at the end,
I told the customer about it and i guess we will see on saturday, i will check all the tiles first. if they are not stuck down i will get them off and use some bagged stuff, it is only 6 tiles.
how deep would you fit tubbed gear and how deep would you fit bagged?
devonmark
For future reference...get yourself a plasterers straight edge or use your longest level and check the walls when you go to price up, that way you will know exactly what you are dealing with, also... you can then work it into your price should you need to if the walls are bowed. If work by someone else has been carried out in between quoting and starting the job always check with an edge or level...Mark.
gm renovations
Yea, P&*%ed off with myself,
I just hope by leaving it 5 odd days i will know if it has set,
If not i will get them off, will not be that bad as it is only a few tiles and i have to grout the rest of the room and floor so by the time i have done that they should have set,
You live and you learn,
How far can you build out with rapid set and flexible rapid set?
GazTech
Thanks mate,
i will get to the job early on sat and test all the tile, i will really test them to see if they are cured,
If they are i will grout if not i will replace with rapid flex,
Just worried now!!!!!
No need to worry, you would know if they had tumbled off the wall by now. And you have the perfect solution......Gaz
Reply to What do you guys think in the British & UK Tiling Forum area at TilersForums.com
Hi everyone, I'm not a regular tiler, just someone who is trying to fix up a few rooms around...
    Votes: 9 5.3%
    Votes: 17 10.0%
    Votes: 12 7.1%
    Votes: 49 28.8%
    Votes: 21 12.4%
    Votes: 40 23.5%
    Votes: 4 2.4%
    Votes: 4 2.4%
    Votes: 23 13.5%
    Votes: 19 11.2%
    Votes: 17 10.0%
    Votes: 8 4.7%
    Votes: 5 2.9%
