Discuss What is the best way to remove tile adhesive from plasterboard? in the British & UK Tiling Forum area at TilersForums.com.
jonny_cinnamon
Hi Everyone
I am currently refitting my kitchen. I have started by removing the tiles from the walls but the plasterboard is now a mess with patches/lumps of tile adhesive still stuck to it. All the the tiles have been removed by bolster chisel and as you will all know, the bare plasterboard is now a mess and I need it to be clean before I can start putting the new tiles up.
The problems I have are as follows:
The walls in my house are not standard Timber Stud partition walls with plasterboard fixed to the timber frame. If they were then I could just remove the plasterboard and put new plasterboard up. The walls are paramount partition walls, they have a timber header plate at the top and a timber footer plate at the bottom with a cardboard grid system in between. The plasterboard is then glued to the cardboard grid. It is like an eggbox cardboard system. I can't remove the plasterboard as it will rip the whole wall down. The house was built in 1970 and this was the walls the construction company choose to use which is now not practical.
What is the quickest and tideist way of removing the tile adhesive?
Last year I refitted the bathroom and I had the same problem with the tile adhesive mess on the plasterboard. Then, I used an electric sander to sand the tile adhesive off which is time consuming and creates alot of dust. I don't want to do this again as we now have a 6 month old baby in the house and I don't want to create alot of dust in the house. I have been chipping the tile adhesive off the plaster board today but again, this is time consuming so what advice does anyone else have?
Hope someone can help
Jonny.
AliGage
Subscribed
4,531
1,188
Peterborough, England
Pull the plasterboard down. There's a timber frame in there somewhere. It's usually about 2" or 50mm timber, but there's not a lot of it. Break out some of the card inside and screw in some more timbers. Re-board using feather edge plasterboard and fill the joins with an easy filler.
widler
1,328
England
if they are the same as ive seen before,there is no timber frame in there,just cardboard.
did some council houses years ago,when plasterboard was taken off the bloody wall could be pushed through,its a bit like metal stud,when no plasterboard on they are as wobbly as bambi and when boarded they go solid (ish)
jonny_cinnamon
Hi everyone,
Thanks for your posts & advice. My house is an ex-council house and unfortunatley there is no timber frame inside the walls, just cardboard. I know this because from doing other work in the house. It is not practical at all.
I have been using a scraper like kendo1 mentioned to remove the tile adhesive but I thought I would put a post on here to see what other peoples opinions were. My hands are taking a battering using a scraper!!!!
I'm afraid I haven't got round to using a steamer yet due to looking after our wee boy today but hopefully I'll get round to it tomorrow.
Thanks again for everyone's help. Its much appreciated.
jmc1234
Came accross the same problem today.... remove the nails from top and bottom, cut/score 2 ft squares with stanley knife, then I used a plunge cutter to make a hole were i could get a grip of the plasterboard and then just pulled it off while using the other hand to stop the wall caving in. Damaged about 5% of the cardboard grid which doesnt really matter as i have put some extra timeber supports in and fixed new plasterboard to these. Good luck with it....
Reply to What is the best way to remove tile adhesive from plasterboard? in the British & UK Tiling Forum area at TilersForums.com
Hi all - I have some small format ceramic tiles (10x10x1cm) to use as a splash back around the...
    Votes: 14 9.4%
    Votes: 44 29.5%
    Votes: 17 11.4%
    Votes: 35 23.5%
    Votes: 21 14.1%
    Votes: 18 12.1%
    Votes: 16 10.7%
