Discuss What plasterboard to use for travertine? in the Canada Tile Advice area at TilersForums.com.
robbieee
Putting plasterboard up on studwork and i am unsure what plasterboard to use? The moisture resistant stuff? Its just a general bathroom with a bath/shower, extraction fan, toilet and basin.
I will be tiling directly onto the plasterboard, will i be better off with the tapered edge pasterboard then as i won't be skimming?
How should i prime the plasterboard aswell? Is this needed?
Sorry for all the questions!!
SJPurdy
check that the weight of your tiling (tiles + adhesive+grout) does not exceed 32kg/m2 on the (assumed correctly fitted) plasterboard. (I guess that is equivalent to trav of 10mm thick). The weight limit for the top half of your walls (lath and plaster) will be much less (plaster weight limit is 20 kg/m2 - assuming this even applies to lath and plaster!) and so unless you have thin trav. then I would recommend these are replaced with plasterboard (or better) if you want to tile them.
Reply to What plasterboard to use for travertine? in the Canada Tile Advice area at TilersForums.com
Hi all - I have some small format ceramic tiles (10x10x1cm) to use as a splash back around the...
Hi, trying to find my way around this question. We had a new bathroom built, it was...
Sealing Moisture resistant plasterboard Hi I am new here, I have been reading through many of...
10K
Hi, prepping room for tiling. 6mm hardibacker on floor and 12m in shower area. rest of room &...
6K
L
    Votes: 5 4.7%
    Votes: 8 7.5%
    Votes: 6 5.6%
    Votes: 29 27.1%
    Votes: 14 13.1%
    Votes: 27 25.2%
    Votes: 3 2.8%
    Votes: 2 1.9%
    Votes: 19 17.8%
    Votes: 18 16.8%
    Votes: 13 12.1%
    Votes: 5 4.7%
    Votes: 3 2.8%
    Votes: 1 0.9%
