Discuss What primer should I use for a concrete floor in the British & UK Tiling Forum area at TilersForums.com.
mjps
HI, I am about to tile with porcelain tiles onto a concrete floor in a new build flat.
Tiles are I am told 30 x 40cm.
Three areas to do, bathroom, kitchen and hall.
Floors are apparently dry and confirmed as such, because client is having a wooden floor also installed in the lounge area and has had damp/humidity test done.
So, is there any primer that I should put down first?
I intend to use Ultra one part rapid flex adhesive with matching Ultra flexible grout.
Thanks in anticipation. Karl, MJPS, Leeds
Reply to What primer should I use for a concrete floor in the British & UK Tiling Forum area at TilersForums.com
PVA V PRIMERS – WHy you should never use PVA Glue when Wall Tiling Don’t listen to that idiot...
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.3%
    Votes: 17 11.3%
    Votes: 36 24.0%
    Votes: 21 14.0%
    Votes: 18 12.0%
    Votes: 16 10.7%
