Discuss what to put with this ? in the Canada Tile Advice area at TilersForums.com.
Rizzle from the Portizzle
well you know we tiled this a couple on months ago and could not think what i could put on this set it had to
be classic to work with the tiles but it had to be different we came up with this now the question is with or
without Lara Croft.
DSC00053.JPG DSC00062.JPG DSC00063.JPG DSC00064.JPG DSC00065.JPG DSC00070.JPG DSC00072.JPG DSC00074.JPG DSC00075.JPG
Tile Shop
Had an issue with Halcon Atrium tiles. 60x30, 6mm. Most of the range was ok, but not this batch of this colour.it was a 2mm bow, so on the limit of tolerance. And no matter how much you explain to customers it conforms to BS, try a different layout, etc, they still think the tiles are faulty and it has to be brick bond.
Simple solution sent them a genesis levelling kit which was just strong enough to flatten them until the adhesive was set :)
I've seen some of the porcelthin videos and the larger ones look very wobbly but strong. no chance of bowing being a problem with them. Looked as if you could almost bend them into whatever shape you wanted without them snapping. (Ok, maybe i'm exaggerating slightly).
Actually @Ray TT @ Porcel-Thin , These porcelthin tiles, I'll use 1200x600 as an example, how much can the be bent before shattering? and can they be used on slightly curved walls?
about 28mm they wont curve round a wall as they will fight back and go straight here some pictures
Reply to what to put with this ? in the Canada Tile Advice area at TilersForums.com
Looking for some technical advice on these tiles please. Our installers fitted this CaPietra...
Hello: First time posting. Looks like a really good forum for Info. Here is my question: I'm...
I'm looking for solid answer or opinion. We had some windows removed on an exterior wall and...
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
