Discuss what to use in the British & UK Tiling Forum area at TilersForums.com.
tricky15
Hi
I'm currently on with doing my bathroom i'm tiling around my bath from bath level to ceiling on two walls for a over bath shower to be installed. The tiles i've got are 600 x 300 x 10 porcelain tiles, and plan to stick them to wall using Mapei Keraflex addy.
The two walls i'm tiling i'm pulling off the skimmed plasterboard. Can i refix plain plasterboard and tank or do i use aqua panel or something similar i under plasterboard holds upto 32kg per m2
My tiles on box weigh 18.5kg per 5 tiles which covers 0.9m2
please advice i'm in two mind
HELP!!!!!!!!!!!!!!!
tricky15
Hi
HELP!!!!!!!!!!!!!!!
surely the weight of addy won't be more than 12 kg per m/2
tricky15
Plasterboard will be fine, just tank the wet areas, aqua panel is the better option but, a more expensive one, the choice is yours. I'd use a 10mm trowel for that size tile and don't forget to back skim the tiles. Best of luck with the job and don't forget to show us some pics.
Sent via Tapatalk for iPhone
back skim is where you fill the hollows on the back of the tiles then stick to wall. Yes?
ps if i tank the plasterboard does that not act like a painted surface and the weight per m/2 is reduced?
Gazzer
Yes that is back skimming but dont forget that you still spread the wall too.
You need to get the weight info from what ever manufacturer you are using, Usually it is determined by the original substrate.
Reply to what to use in the British & UK Tiling Forum area at TilersForums.com
After annoying the guys in my local CTD for about an hour looking at samples and agonising on...
what to use
    Votes: 14 9.4%
    Votes: 44 29.5%
    Votes: 17 11.4%
    Votes: 35 23.5%
    Votes: 21 14.1%
    Votes: 18 12.1%
    Votes: 16 10.7%
