Discuss What to use? in the British & UK Tiling Forum area at TilersForums.com.
treehouse
Hi Tilers,
I've popped over from the dark side (the electricians forum) with a question to the professional tilers amongst you. I have a shower enclosure with a flat wall cornering onto the curved wall of a basement vault. Tiles are an option albeit difficult, especially for me, so I wondered if there was a wall material similar to flooring for wet rooms that I could use to provide a suitable surface for the inside of a shower.
Thank you
Malcolm
peckers
Think i am reading this right or maybe not, you have a flat wall that leads into a curved wall? you want a suitable finished surface on the curved wall that ties into the curved wall? as mentioned above you could tile the curved wall in mosaics, but you dont want too as you want the grout lines to match with the flat wall is this correct? you could cut your tiles the same ones that are on the flat wall into thin strips this will then allow them to go around the curve.
Reply to What to use? in the British & UK Tiling Forum area at TilersForums.com
  • Sticky
We had our loft bathroom done a month ago and are having issues with the tiler (recommended on a...
Vinny Kehoe
V
Hi I am after some advice and opinion if the quality of our recently installed tiles is of an...
Greetings All, appreciate the expertise existing in this forum. I am a home remodeler, not a...
5K
We’ve recently decided we’d like to tile our narrow chimney breast in advance of fitting a wood...
What to use?
    Votes: 14 9.4%
    Votes: 44 29.5%
    Votes: 17 11.4%
    Votes: 35 23.5%
    Votes: 21 14.1%
    Votes: 18 12.1%
    Votes: 16 10.7%
