Discuss what trowel for wood flooring? in the British & UK Tiling Forum area at TilersForums.com.
barney55
Hi
I have a cloakroom, 3m sq to tile, it is a suspended floor half inch ply, with 6mm wbp screwed down at 150mm centre. I am using a nicobond rapidflexi adhesive on 300mm x 300mm ceramic tile, but the adhesive says to use a trowel that leaves a bed of 2-3 mm adhesive at the bottom with a groved layer above as its a timber floor!! I can't seem to find one of these and what are they called, can anyone shed any light on this please???
barney55
cheers dave
so this type of notched trowel, that leaves a sub base of adhesive with a groved layer above it does not exist?
regarding the floor thickness, there is half inch ply, then I screwed a 6mm ply ontop, but there is height issues with a hall way. what would you of recommended as I did a post about using ditra matting for this, but you and wivers replied that if i beefed the floor joists with noggins which I have done it should be okay with a flexi adhesive. do you think i should use a two part bal fastflex adhesive instead of the nicobond rapidflex?
Reply to what trowel for wood flooring? in the British & UK Tiling Forum area at TilersForums.com
Hi, I am trying to achieve a low floor build up including wet UFH over a new suspended timber...
We are having some issues with our newly laid tiles. Within several weeks of being laid, we...
David John
I have nearly finished cleaning up and sealing 300 reclaimed 6 inch quarries that are 1 inch...
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.1%
    Votes: 18 11.9%
    Votes: 36 23.8%
    Votes: 21 13.9%
    Votes: 18 11.9%
    Votes: 16 10.6%
    Votes: 7 4.6%
    Votes: 4 2.6%
