Discuss What Trowel Size in the Australia Tiling Forum area at TilersForums.com.
Lithofin BOB
518
Hampshire
I have discovered a batch of mosaics I got off a job 15 years ago, limestone 10mm x10x 10 in sheet form paper across , the paper has gone so I have two tubs of squares , I bought the Gemini mosiac plastic 300x300 sticky sheets and have been sticking these cubes to these for the last few days, 21 sheets. ( am loosing the will to live) but they are free, wife mentioned something about me being tight!! These tiles are going on the back wall of a small shower I'm putting in. Contract board and all tanked.
Plastic mesh 2-3 mm deep and the tile 10mm , have a rapid white, what knotch trowel should I use ?
Cheers Bob
J Sid
Think your wife is right.... They always THINK they are.
Not tried the sheets, how much tile is likely to be in contact with the adhesive?
You will need a notch large enough to get a good cover on tile but hopefully not come though the joint. I would be looking at a 8mm as a starting point.
Good luck ;)
May see you on the 4th Dec, if spaces left.
Lithofin BOB
518
Hampshire
Cheers guys I will have a play, 9,000 000 trade days mean I have a full set of old trowel , but this makes for more confusion.
Have already spilt and weighed my adhesive into quarters , so can work small batches
Will be taking this slow.
I am impressed with these plastic sheets perfect for a novice like me and they are fairly solid so should be ok, won't speak to soon
Thanks for advice, will have first go , poss Tom as working in town today , let you know how I get on. Cheers bob
Taking it slow Bob? Hahaha
With rapid set?
Reply to What Trowel Size in the Australia Tiling Forum area at TilersForums.com
Hello. Doing... ( extremely slowly ).. a walk-in shower & additional soaking tub area 1) What...
Oops, I am reposting this into the correct forum Building a walk-in shower & additional soaking...
Hi all, I’ve got three bathrooms to tile using 3.8mm Winckelmans porcelain hexagons (25mm). The...
Hi everyone 🙂.My friend has a cheap ceramic cutting machine that i don't like working with. it...
Lithofin BOB
Hampshire
What Trowel Size
    Votes: 9 6.2%
    Votes: 13 8.9%
    Votes: 11 7.5%
    Votes: 44 30.1%
    Votes: 17 11.6%
    Votes: 34 23.3%
    Votes: 3 2.1%
    Votes: 20 13.7%
    Votes: 18 12.3%
    Votes: 15 10.3%
    Votes: 7 4.8%
    Votes: 3 2.1%
