L
lendini
Hi all.correct me if i am wrong if i am using say large format tiles that are heavy will i work out my centrelines vertical and horizontal to get my cuts right then put a batten on my bottom most full tile and work up using spacers ,then back butter the others in after batten is removed.waht is the maximum size tile in your experiece before you need to start doing this procedure.
could you also tell me how to batten out.would i use srews ,nails, or even no nails to position batten and is wood good for the job on a proffessional scale.many thanks in advance chaps
