Discuss When do you do your cuts? in the British & UK Tiling Forum area at TilersForums.com.
Daz
It's really just a judgement call IMO.
Some rooms are small and it makes sense to dry lay, mark the cuts and stick in one go. Some rooms are straight forward cuts that can be made as you go. Some areas are easier to fire down the field tiles and then mark and fix cuts later, it all depends on circumstance.
The main thing is the end result :thumbsup:.
Aston
i prefer to cut and fix as i go...i would also rather work out my cuts 1st on large areas and real them off so there all done and also ready to fix as i go, rather than doing the field tiles on one day and then doing the cuts the next or when the addy has dried sufficiently..
dom is right about this time issue thing..tiling is a finsihing trade so therefore the quality of your finish is the most important issue. its so much more important to spend that little bit extra time on measuring accurately and precise cutting because thats what people will notice and thats what builds you reputation and the money you can jusifyable charge imo..
ed...
Smaller rooms I always do them as I go so I can finish in one day, i.e. anything around 10m2.
Anything more than that and it is really down to what mood I'm in, as daft as that sounds:lol:If I'm not in the mood, I'll fix all the full tiles, so psychologically it looks like I've done loads:lol: other days I might cut as I go, there isn't really a right or wrong way as long as the finished job is spot on:thumbsup:
Time's Ran Out
Just for amateurs IMHO - and it does depend on the adhesive!
A professional would set out a floor to be able to lay all the tiles in one proceedure and have the floor grouted within the time guidlines of the adhesive manufacturers. It would not be cost effective for the tiling contractor or the customer if the work took longer than the recommended adhesive drying/grouting times.
However if you are asking in terms of a DIY job involving immense enthuisiam then I would concur that the overriding factor being that of the enjoyment and quality of the job and the satisfaction of knowing that you have completed a first class job - no matter how long it took!.
Reply to When do you do your cuts? in the British & UK Tiling Forum area at TilersForums.com
Hi everybody, I am about to lay my patio, 60x60cm porcelain tiles. I have just checked on where...
Hello All, First post in this forum so forgive me if this has already been posted before. From...
AHTiling
Hi, new to forum and first post, after some advice. Recently had the chamber of my fireplace...
    Votes: 9 5.6%
    Votes: 17 10.6%
    Votes: 11 6.8%
    Votes: 44 27.3%
    Votes: 21 13.0%
    Votes: 38 23.6%
    Votes: 4 2.5%
    Votes: 3 1.9%
    Votes: 22 13.7%
    Votes: 19 11.8%
    Votes: 17 10.6%
    Votes: 8 5.0%
    Votes: 5 3.1%
