Batt284
Hi All,
Another one from me I am afraid! I am planning to tile in a brick bond format and it looks like there is going to be a small cut in quite a prominant position. I felt it would be best to lay the border just below the window so that it would be unbroken all the way around. However, plotting where the border would be positioned all the way around the room (red lines in the picture) reveals that the tile below the border is going to slightly (38mm) overlap the raised box at the end of the bath that conceals the pipework.
If I was to maintain the same horizontal grout line all the way around I would be left with a 38mm cut at the top of this box (shaded in orange). Do you thing this would look acceptable? If not do you think a different layout (i.e. not brick bond) would be acceptable on the box? As ever any thoughts much appreciated.
Thanks, Ben
Thanks, Ben
