Discuss Which adhesive for Shower/Bathroom area in the Bathroom Tiling Advice area at TilersForums.com.
wolfwiser
Hi, first post so be gentle!
I've had a look about but can't seem to find an answer - I'm about to tile my bathroom. I'm using 415 x 300 mm wall tiles and 300 x 300 mm floor tiles. I've decided its well worth spending the money and getting BAL (or Mapei) powdered tile adhesive, and probably jasmine powdered grout. I shall be staggering the tiles
The question is which BAL products should I use?? I'm a bit confused with all that's on offer. I realise I need flexible floor adhesive.
Is 2 mm spacers for wall and 3-5mm for the floor common?
Where is the best place (shop) to buy said products (tile giant, Topps etc.)
Many thanks for any advice in advance.
:thumbsup:
Rich
Pop in to tile giant if there is one close to you, they will be able to sort you out in no time. You will want a standard setting cement based adhesive for the walls and I would go for a rapid for the floor.
What are you tiling onto? What are the walls and floor made of?
Oh and welcome to the forum :thumbsup:
wolfwiser
Thanks guys, I have a tile giant very close by! I guess its an 8mm trowel I need, would this suffice for the floor also or am I mistaken? I shall be also running a mosaic band all round the bathroom, do I need differing adhesive/grout for this too?
I'm tiling onto aquapanel around the shower area and standard plasterboard in the 'dry' areas. I believe I need to treat the plasterboard prior to tiling, any recommendations? Also, I may be in the wrong place for this question, so apologies in advance - Do I need to 'tank' the aquapanel gaps between boards? I've read differing thoughts, I can always head back to the DIY forums for that one!
Thanks for the quick responses, I like it hear - I feel welcome!!
Rich
8mm should be fine for the walls but not the floor, get yourself a half moon trowel. You need to try to get 100% coverage of adhesive under the tiles and these trowels make it easier to do that. Also spread some adhesive onto the back of the tile with the flat edge of the trowel before pressing the tiles into the adhesive bed.
You shouldn't need to tank the aqua panel but it would do any harm if the budget allows.
Rich
Need some keraquick white 20kg bag anytime now so ringing Tile Giant I was quoted £41.99:yikes:
An independant locally quoted £27.48 so it pays to ring round.
I'm assuming you pros get a good discount by setting up an account but the wouldn't budge on price for me.
There are some good discounts available through this forum if you use it enough to gain TF arms/truster advisor status but yes, they are more likely to give better discounts, the more money that you put through them.
Reply to Which adhesive for Shower/Bathroom area in the Bathroom Tiling Advice area at TilersForums.com
Hello, I'm having trouble finding any decent stockists locally. I've got a Topps very near, plus...
I've got an AKW Tuff form shower tray with a waste that is 10mm above the tray when fully...
Unsolved
    Votes: 9 6.2%
    Votes: 13 8.9%
    Votes: 11 7.5%
    Votes: 44 30.1%
    Votes: 17 11.6%
    Votes: 34 23.3%
    Votes: 3 2.1%
    Votes: 20 13.7%
    Votes: 18 12.3%
    Votes: 15 10.3%
    Votes: 7 4.8%
    Votes: 3 2.1%
