Discuss Which Grout For Porcelain Wall Tiles With 2mm (small) Grout Joint? in the Australia Tiling Forum area at TilersForums.com.
[QUOTE Boardley, post: 773355, member: 36125"]tilemaster 3000 for me, love the stuff (well as much as you can "love" grout haha)
Same question cam ....whats the weber like?[/QUOTE][QUOTm_low, post: 773352, member: 5067"]I have just used webers grout again for the first time in a long time!!! so smooth an lovely to work with. I dont have access to tilemaster 3000 to try theirs....yet
Didn't know I could do 2 quotes in one post lol
Really?! As in bottled water?I found the weber left a few pinholes but that was sorted with a quick fill and a rub down with my finger and medical glove. I mix my grouts with distilled water and wash down too.
Going to try the tilemaster 3000 on my next job.....anyone know how to find the nearest stockest of the stuff......im in Gloucester
Ahhhh - bottled isn't distilled, usually. And does have minerals in (if it's spring water etc). Distilled is when you boil it and catch the condensation when it's perfectly at 100 degrees at sea level, lower temperature higher up.yes dan. ive had so many issues with micromax 2 and patchy grout and its certainly not from overwashing I have had to try this, a little tip from an old friend. it seems to have worked. the water down london is very hard im just certain its got something to do with it.
Right ....got some grout 3000 mid grey to use on some 600x300 pors on the walls.
Im used to using bal grouts....is it similar to use? Would normally grout 5/6 m2 wiipe it off..let it set for an hour or so and polish the dust off with a dry cloth.
I use Ultra adhesives and slc but always found their grouts (other than standard wall grouts) to be quite course. Is this still the case?I'd use Ultra Flexjoint wall and floor from 1mm-20mm joints...
Reply to Which Grout For Porcelain Wall Tiles With 2mm (small) Grout Joint? in the Australia Tiling Forum area at TilersForums.com
