Discuss Which Sigmas To Buy in the Tiling Tools area at TilersForums.com.
Q
Qwerty
Ok, finally sorting out moving to Sigma from Rubi.
I currently have two Rubi cutters- a TX900N and a TR400S.
I want to replace both with similar Sigma cutters but I want the big cutter to score & cut at least 1225mm and the smaller cutter minimum score & cut of 600mm.
I want push to score and I like the look of the breaking mechanism that flips down.
Which ones should I go for as there seems to be so many different models!!!
Cheers all :)
gamma38
1,058
Bedford
The klick klock handle is a regular push handle but then when you want to break the handle does a 180 deg flip over away from you to then push down and complete the break, if that makes sense. Also i think i am right in saying the max machines and handle has the greatest breaking strength.
I
Italy
Don't bother with klik klok. Stick with push Max handles. I've got a 3em (heavy beast) and 3cm as my most used cutters. Highly recommend both of course...
Reply to Which Sigmas To Buy in the Tiling Tools area at TilersForums.com
Hi everyone. Tiling my bathroom first time and going well so far! 600x300 ceramics on walls and...
Hi all, Im a DIYer doing a lot of work on an old house we are f restoring. I have put down a...
    • Winner
    • Informative
So as a couple of you may be aware, @Simon Dale his daughter Katrina, and myself are on a...
11K
L
Tiling Tool Popular Threads
Tilers Forums on FB
