PJPro
Hi.
I'm laying large format porcelain tiles over screen with wet underfloor heating. I'm using Ditra as an uncoupling membrane, with Schulter movement joints at door thresholds. As the title of this thread suggests, I'm not sure which size trowel I should be using under the Ditra.
The Schulter UK website suggests a 4 x 4 mm square notched trowel. A US Forum recommends either a worn 1/4 x 1/4 inch (6 x 6 mm?) or 11/64 inch (4.5 x 4.5 mm?) square notch. I can't find much discussion on UK forums. Here's the link to the US site.
Trowel size for Schluter Ditra - Ceramic Tile Advice Forums - John Bridge Ceramic Tile - http://www.johnbridge.com/vbulletin/showthread.php?t=97032
Some say that using too big a notch reduces the effectiveness of the membrane and makes it harder to avoid lumps and bumps in the matting. Others say the 4 x 4 mm size is understated and provides too little adhesive.
I've tried to source a Schulter Ditra trowel but they don't seem readily available in the UK. I was thinking of buying a 4.5 mm or 6.0 mm square notch Rubi trowel. Which one should I get?
Incidentally, I was going to use Mapeker Rapid Set Flex to bond the Ditra to the screed. I assume this is OK? I have primed the screen and then topped this off with some Mapei self levelling compound....so the Ditra will need to bond to the self levelling compound.
Any advice will be gratefully received.
