Discuss White Grout Getting Dirty in the UK Tiling Forum area at TilersForums.com.
I
Ian
Probably not what you want to hear, but most fitters won't advise white grout on floors for this exact reason, if possibe rake it all out and regrout with a light grey, this will still be light in appearance but not show the dirt as much, white epoxy grout is the only white grout i've ever used on a floor and that can be cleaned, but is still high maintenance and not advisable for a high traffic area such as a kitchen S7300371.jpg
DHTiling
When light grouts are used and a customer just goes ahead and mopps it. this can push muck into the joints wet..
It is wise to hoover first and then mop with little water and not soak it.. A micro fibre mop head is advisable IMO and is what i recommend to customers floors i tile..
Grout sealers can help but again not 100% at keeping surface muck out that gets washed in..
Hope that helps a bit..
Reply to White Grout Getting Dirty in the UK Tiling Forum area at TilersForums.com
Hi, Need to choose a grout for the above. For the black floor tiles 300x600 am thinking either...
Hi any info on get rid of epoxy grout haze on natural stone would be much appreciated. I’ve used...
After annoying the guys in my local CTD for about an hour looking at samples and agonising on...
Hello, after tiling the kitchen area I did grouting but I am not happy with the results. The...
