Discuss White grout is grey in the British & UK Tiling Forum area at TilersForums.com.
whiskeybravo
Hello
I've been regrouting my shower with Mapei utracolour plus white.I have read that it can be tricky stuff to work with so was careful to try and follow the instructions.
The mix seemed too powdery and dry with the recommended amount of water added,so I put a little bit more in just to make it a bit more workable.Even then it didn't fill the gaps easily.
I dressed up the grout, cleaned down the tiles and left to dry.However over large parts of the walls the grout is dove grey in colour.I thought ok it may need to dry out a little longer but it's been 5 day's now.It looks worse than the grout I raked out!
Do you chaps have any idea's what may have happened and more important,any solutions,save raking it all out again.
Whiskey Bravo
kilty55
1,113
edinburgh
if thats the case doug surely it would be the same for bal,pci etc to name a few all must be correctly mixed to acheive correct coulour? i have used all 3 companys white grouts and mapeis comes out as whiskeybravo says its dull its not a good white colour. i first questoned it the 1st time i used it as it was grey when mixed but did dry lighter once cured,,however used with a gloss white tile it ruined the finished article im afraid i dont think mapei have got this quite right however all the other grouts i have used of theres are great.
whiskeybravo
Thanks for the replies.
Whitebeam, sorry I couldn't tell you the adhesive colour as the tiles are quite thick.I did use a fein to remove the old grout and pretty much got it all out
Doug,'slake', I had to look that up.Is that the term used to dress up the grout with a sponge after refilling in between the tiles.If so yes I did and used clean water with 2 buckets for cleaning off the grout.
The tiles are a glossy white and as said they do show up the grout even more.
Whiskey Bravo
Reply to White grout is grey in the British & UK Tiling Forum area at TilersForums.com
Hi, Need to choose a grout for the above. For the black floor tiles 300x600 am thinking either...
After annoying the guys in my local CTD for about an hour looking at samples and agonising on...
Hello, after tiling the kitchen area I did grouting but I am not happy with the results. The...
White grout is grey
    Votes: 9 5.8%
    Votes: 15 9.6%
    Votes: 11 7.1%
    Votes: 46 29.5%
    Votes: 19 12.2%
    Votes: 37 23.7%
    Votes: 4 2.6%
    Votes: 21 13.5%
    Votes: 18 11.5%
    Votes: 17 10.9%
    Votes: 7 4.5%
    Votes: 3 1.9%
    Votes: 4 2.6%
