Discuss white grout in the British & UK Tiling Forum area at TilersForums.com.
susbin
Hi there,
I'm tiling my bathroom (wetroom) at the moment and bought some Bal Micromax wall+floor grout in white, as all the specs sounded good. However... it's not drying white but more like a grey. Considering that all my tiles are white this is not good!
Have done some googling and found Ardex-Flex FS wall+floor grout which sounds like it will do the job (doesnt have microban like the bal but some dirt-resistant properties i understand), and it appears to be sold in brilliant white.
Does anyone have any experience of this grout - mainly does it actually dry white or will i be disappointed again?!
Many thanks for any advice.
Dan
Admin
Staff member
5,096
1,323
Staffordshire, UK
Hi Susbin,
There are dozens of whites when it comes to grout. Some ice-white, some white-white, some creamy-white. You generally need to see the sample board(s) in the shop to get a good feeling of what it looks like when it has set.
If it's an even colour but not quite what you expected it probably will just be showing up due to how white your tiles are and probably is the correct colour. But just in case check to see if it's patchy at all as that could suggest a dirty mixing bucket or the wet grout pulling some colour from the adhesive or something like that.
BAL Superflex is "brilliant white" which is a very sharp clean white. But I never used to like grouting with that stuff. So perhaps check that out too?
susbin
Hi Dan,
thanks yes i do have the Superflex in mind too, the only problem with that is it's only good for walls is that right?
i'd rather have the same grout across walls and floors if i can. (And yes i know the pitfalls of white grout on the floor and am still determined to give it a go...!!!) A man in Topps Tiles recommended a paint-on sealer which will hopefully keep it a bit cleaner for longer.
Dan
Admin
Staff member
5,096
1,323
Staffordshire, UK
Yes sealing the floor grout would be very wise. But you might have to seal the lot for the colour to still match.
If you're looking for the same colour grout for walls and floor superflex perhaps ins't the one for you.
Have you grouted some already to see the colour when 'dried' then?
I
Ian
Because it's a wide joint grout designed to be flexible and suitable for walls and floors it seems to contain a lot of sand, I would say that it is this that is giving it the 'grey' appearance. According to Topps, who I assume have got their info from BAL, it's meant to be an 'all-in-one' grout, suitable for every job. Seems they may have overlooked the white one :lol:
One Day
What issues are there Impish? New to me that is!
Is it colour-related or more batch related or something?
I heard they are reviewing the grouts after quite a few colour issues.
The idea behind the micromax range is great and for BAL, is long overdue.
Until they get the formulation right though - only the idea is great!
Surprising for BAL to have this problem really.
Reply to white grout in the British & UK Tiling Forum area at TilersForums.com
Hi, Need to choose a grout for the above. For the black floor tiles 300x600 am thinking either...
Hi there. Wondering if anyone can help? We had a path laid using reclaimed quarry tiles on top...
After annoying the guys in my local CTD for about an hour looking at samples and agonising on...
white grout
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.3%
    Votes: 17 11.3%
    Votes: 36 24.0%
    Votes: 21 14.0%
    Votes: 18 12.0%
    Votes: 16 10.7%
