Discuss White residue on porcelain (slate finish) in the Australia Tiling Forum area at TilersForums.com.
I
icctiling
Hi all
finished laying 600x300 porcelain (slate finish) and grouted, in my sisters bathroom.
went to check them about 2-3 days later and found a white chalky residue on tiles.
very random, i.e. Some on centre of tile, some close to grout lines.
checked the remaining tiles out in shed and a light speckle of white residue is on unused tiles.
initially thought some effervescence and have treated with tile cleaner but still some remaining.
when tiles are wet the residue disappears.........would anyone recommend treating with some form of oil (baby oil??) to bring up the slate finish and erase the white residue ???
just asking if anyone has come across this, and how can I treat?
Any advice would be great
thanks in advance
Dave
Staff member
Subscribed
389,929
1,000,000
Co.Durham
It could be polymer or cement residue from the grout , try some lithofin cement residue remover first , should do the trick , use a diluted mixture first on an inconspicuous area , towel dry and see results .. Use a stronger dilution if not removing .. Wear appropriate PPE...
Lithofin BOB
518
Hampshire
You state the same contamination / lighter is on the unlaid tiles, this may be a whitening to a possible transit wax, or manufactures coating . test the cem res remover as suggested by david or if your tile cleaner is acidic based - re clean, contact your supplier , they can often tell you if there is a coating that may need to be removed or if they have had this before.
if this was a transit or polymer based issue you wil need an alkali based cleaner not acidic to poss break this down.
Reply to White residue on porcelain (slate finish) in the Australia Tiling Forum area at TilersForums.com
A question about mitering and matching epoxy colour I'll be working with some pinkish matt...
I’ve got some white adhesive residue stuck to the surface of black slate effect tiles. Give them...
Hey everyone! Just want to say first of all that I am not a tiler or anything I’m just in need...
6K
N
..my tiler has grouted my bathroom and hasn't cleaned the grout off properly....the tiles are a...
28K
Annieganatra
    Votes: 13 8.8%
    Votes: 11 7.5%
    Votes: 44 29.9%
    Votes: 17 11.6%
    Votes: 35 23.8%
    Votes: 20 13.6%
    Votes: 15 10.2%
    Votes: 7 4.8%
